Your antenna is the problem. First work on that and see if you get enough power to broadcast through the house. Commercial AM radios use small guage magnetic wire wound around a ferrit rod about 4 inches long and about 3/8 inch in diameter. Wind 240 feet on this rod. You can also just salvage an antenna from an old radio which you might find at the Salvation Army. I do this for antennas, transformers and variable capacitors.
As for rf amplifiers they just amplify rf and they come in many types including the Common Emitter amplifier used in your oscillator. As for your needing another stage of rf gain, I don't think so now. You need a proper antenna.
