Hi wanting to confirm my schematic for programming ESP 32 S3.
I am also wondering if this is the simplest solution to program the ESP 32 S3 do I need the auto-program circuit? what workaround is there not to have that without a button can I simply disconnect and reconnect the USB port? or do I not need this since using the FTDI to program?
Can I program directly via USB using D+ and D- this way no need to use the programmer. I have attached another version of that as well. From the data sheet I am not sure what the values should be or if they are needed. (esp attachment)
Edit - I made a new circuit using the data sheets for ESP 32 to the best of my ability (new prog)
