Reversing 30V polarity with microcontroller
zijo
Joined May 20, 2017
8
I have 30V low power supply (10-20mA) and I need to reverse it at 10 Hz using microcontroller operating at 2.7V.
I am wondering what will be the best way to do it?
I looked option of H-bridge using mosfet but I am not sure if circuit will work with so different voltage levels, because gate G/S voltage is ~20V.
zijo
Joined May 20, 2017
8
Yes.
I never used before mosfet, But GS voltage would be to high.
Cant find any circuit on the net maybe PNP/NPN transistors would be better.
SInce it is not a large current maybe using OP-AMP is better but they constantly take ~5mA per channel.
Motanache
Joined Mar 2, 2015
652
I wanted to say about the MOSFET driver but I had doubts. IR2110 is one of the most popular.
MOSFET Q1 needs 12V above OUT voltage.
For example V + = 30V , V gate q1 = 42V.
This is done with the floating source.
C1 is charged through D1 when Q1 is OFF.
The C1 charge is the only one that supplies the gate voltage for Q1.
The circuit in the figure works very well at some frequency.
But will it be able to keep Q1 open for a long time?
3h=10 000s, if R3 does not exist and the leakage current of the gate would be 1nA
C=Q/U=I*t/U Would probably work.
I would do it with discrete components. And another voltage of 12V for the gate.
Motanache
Joined Mar 2, 2015
652
I tried the first link. The frequency must be between 2500Hz and 1000 000Hz.
I would have been curious at 2Hz or at 0..02Hz.
From link that capacity increases with frequency decrease. But I stop here. Do not continue a parallel discussion.
It is possible that the assembly works in the test, and more time is used without changing the state to burn Q1.(maybe I am wrong)
MaxHeadRoom
Joined Jul 18, 2013
30,628
Also that is the stepper circuit, there is one for the DC motor also.
P.54
Two controllers on the board.
Max.
