resetting i2c device on PCB? i2c locking up
DJ_AA
Joined Aug 6, 2021
502
Hi All
I have experienced few time my PCB locking up. I suspect its related to i2c., as it's not going past the i2c operation. My i2c devices are simple sensors.
Is it possible to preform some type of global i2c device reset, at the power-up of the PCB?
Has anyone experienced i2c every locking up, which result in power cycling the PCB?
Jon Chandler
Joined Jun 12, 2008
1,660
I had this problem using a DS3231 clock chip. This recommendation is in the datasheet. Doing this solved the problem.
".... it is possible that the microcontroller and DS3231 I2C communications could become unsynchronized, e.g., the microcontroller resets while reading data from the DS3231. When the microcontroller resets, the DS3231 I2C interface may be placed into a known state by toggling SCL until SDA is observed to be at a high level. At that point the microcontroller should pull SDA low while SCL is high, generating a START condition."
Toggling the SCL port pin maybe 8 or 10 times solved the problem.
Papabravo
Joined Feb 24, 2006
22,116
Yes. You should be able to recover all of the devices on the I2C network by doing STOP condition followed by a START condition with a new transaction. At least, that has always worked for me.
DJ_AA
Joined Aug 6, 2021
502
So on any power cycle or if the microcontroller is reset, is best to force the data pin low and toggle SCL multiple times? Is there a delay in toggle we need to keep in mind, otherwise the toggles could be to fast? I presume this toggle are simply H and L of the GPIO pin.
Jon Chandler
Joined Jun 12, 2008
1,660
I didn't force SDA in any way, just SCL, as I call when the micro was starting up. I don't recall if it was something as short as 10mS or even 100mS toggling during startup, after which I reinitialized the I2C.
DJ_AA
Joined Aug 6, 2021
502
So do we need to set the Registers in uC for I2C, or does this all happen before the first i2c setup?
So do I keep the GPIO connected to SDA as input, and observe it going high?
DJ_AA
Joined Aug 6, 2021
502
My device recently locked up, but luckily it was at my desk.
Using my debugger i read the status of the SDA pin, to be High and not as low. But it was still locking up, therefore I added the following code, which is CLocking the CLK pin of all my devices and it seems to solved my problem. Maybe I can add this code on the startup sequence of my PCB. How does others reset there i2c?
Code:
void i2c_reset(void)
    PORTC.DIR |=  (1 <<1);
    for(uint8_t x =0;x<20;x++)
    PORTC.OUT |=  (1 <<1);
    _delay_ms(10);
    PORTC.OUT &=~  (1 <<1);
    _delay_ms(10);
Papabravo
Joined Feb 24, 2006
22,116
I2C is a protocol that depends on the history of what has happened on the two lines SDA and SCL. If for any reason, there is a protocol violation then a lockup is possible. In my experience there is nothing wrong with taking defensive measures when they cannot hurt you and might help you. In this case the defensive measure is to always begin each transaction by executing a STOP before executing a START. In that way the interface always begins each transaction with a known good condition.
DJ_AA
Joined Aug 6, 2021
502
Thanks, i will also preform a stop() before starting a new communication. Does is pulsing the CLK simply finishing of a unfinished communication cycle?
Papabravo
Joined Feb 24, 2006
22,116
I have not looked at the I2C specification in a while so I can't answer your question immediately. I will dig it up and get back to you.
Jon Chandler
Joined Jun 12, 2008
1,660
I came across the toggling technique in the datasheet for the Maxim DS3231 clock chip. From the datasheet:
The I2C interface is accessible whenever either VCC or VBAT is at a valid level. If a microcontroller connected to the DS3231 resets because of a loss of VCC or other event, it is possible that the microcontroller and DS3231 I2C communications could become unsynchronized, e.g., the microcontroller resets while reading data from the DS3231. When the microcontroller resets, the DS3231 I2C interface may be placed into a known state by toggling SCL until SDA is observed to be at a high level. At that point the microcontroller should pull SDA low while SCL is high, generating a START condition.
Papabravo
Joined Feb 24, 2006
22,116
Sadly the actual I2C specification, originally written by Philips (now NXP), is no longer publicly available. However, you might find this AppNote useful:
https://www.nxp.com/docs/en/application-note/AN10216.pdf
It clearly defines a STOP condition on p. 14
Because both SCL and SDA are driven by open collector (drain) drivers the pullup resistor on SCL should guarantee that it is high when all devices are inactive. This will allow you to take SDA to a low condition and then allow it to return it to a high condition to create the STOP condition. There may be a period of time you need to wait after generating the STOP condition for normal operations to resume.
Ian0
Joined Aug 7, 2020
13,317
Hi All
Is your I2C a real peripheral, or is it implemented in software?
Generally, I find if I2C ICs lock up on a software-implemented interface, it's something daft I've done in the software interface, like forgetting to start the SCL and SDA lines high.
Papabravo
Joined Feb 24, 2006
22,116
Its a hardware periperal . I am using the XMEGA.
I'm confused. Why do you think that matters?
My point is you have to know the peripheral on the processor well enough to get it to do what you want it to do. I never had a problem with the ATmega128 or the ATmega2560. why should the XMEGA be any different?
If you still need help, send me a link to the processor datasheet and I'll take a deep dive.
DJ_AA
Joined Aug 6, 2021
502
When we preform a Stop command, i belive that will reset any active i2c device, or would we still need to pulse CLK for the vus?
