I currently own a Chromebook C213N, and am attempting to manually reset the bios chip.
The chip in question is the 8-pin winbond W25Q128FW and after looking at the datasheet (attached), discovered the reset pin.
I believe I have to short this pin to ground if I am to manually, if messily, reset the chip (could someone confirm this?)
My question is: whilst doing this, should it be turned on, should the battery be connected to the motherboard at all, or should all power be disconnected whilst doing this?
Many thanks!
Many thanks!
