I'm looking to build (TIG weld) a dust collector for a sandblast cabinet capable of achieving 400 cfm (recommended by the manufacturer as the minimum for this particular blast cabinet). Collecting dust in the corner of my shop is a Baldor 1hp three-phase motor with blower and Baldor VFD currently setup to input 120vac and output 240v three-phase (pictures attached). A little research seems to indicate this Baldor motor/blower is pretty similar to their DC14-3 dust control system for bench grinders, and the specs I'm reading for that show 700 cfm running with three-phase supply with a simple bag filter/collector. (That's also a 1hp motor.)
I would like to maintain the 120vac input for this motor since it will be connected via the light bar on the sandblasting cabinet. In so doing, I expect I won't be able to achieve the full 700 cfm (or that I'll be pulling a lot more amps to do the same work). I know that CFM is highly dependent upon a lot of variables such as fan blade size, filter size and type, housing construction, ducting diameter (which will be 4"), etc.
I'm looking to probably build a DIY dust collector similar to this Econoline unit which sells for about $2K, but scaled down a bit:
Filters for this unit are widely available - here is one supplier:
https://damnfilters.com/products/495114-econoline-oem-replacement-dust-collector-filter
I'll probably skip the pneumatic vibrator for the initial build and just routinely give it a vigorous whack.
My current idea is to see if I can find an enclosure on Craigslist - my initial thought would be a metal gym locker since it has the access from the front, but certainly isn't dust tight. That's fine as I can add gasketing and weld any holes closed, and reinforce with L channel around the outside if necessary. Open to any better ideas on what I might be able to salvage to make this work!
So what's my question? Is this motor/blower/VFD a viable potential solution here?
