Replacing rectifier tube with diode...
Externet
Joined Nov 29, 2005
2,678
Hi.
An old oscilloscope with a 1V2 rectifier tube on a 1170 VAC winding to yield 1600 VDC to a CRT grid is asking for a replacement. A diode on hand is DTV32F = 1500V 10A / TO220
Should I try ? What can be the worse it may happen ?
dendad
Joined Feb 20, 2016
4,641
Smoke!
You should go with a diode at least twice the voltage, and a bit more for safety I reckon.
And a 10Amp diode is a bit high.
And is the diode in a mains frequency circuit or a high frequency one?
Externet
Joined Nov 29, 2005
2,678
Smoke is fine :D It is 60Hz part of the power supply, and found that among my million parts cannot find a 560K and a 220K resistors needed too. :( Nor diodes for 2KV :( Tube equipment is hard to repair now... If I have to order a resistor they will want to squeeze $19.99 plus $19.99 shipping. Time to add a bunch of lower values :(
28,367
For this application I suggest three 1000 volt diodes in series, 1N4007's, rated 1 am and 1000 PRV.
And the worst that can happen is the diode fail shorted and the high voltage winding of the transformer would then fail open. Then you have a serious problem.
Externet
Joined Nov 29, 2005
2,678
1N4007 are 1KV. Will have to be in series. No 1N4008 after scanning 4 CRT TV cadavers in my junk... Just the mentioned one.
dendad
Joined Feb 20, 2016
4,641
You could try an EHT rectifier from an old TV or monitor. They may have a high forward voltage drop but could be worth a go.
DickCappels
Joined Aug 21, 2008
10,661
As dendad mentioned in post #2, the Peak Inverse Voltage (PIV) across a rectifier in a simple peak detector circuit is approximately 2X the peak input voltage.
This means that your rectifier must be able to survive a peak inverse voltage of 1,655 volts without damage.
Two 1N4007 diodes connected in series should work nicely provided the average current is well under 1 amp. (For a safety margin 750 ma should be the limit,, for higher currents diodes rated at higher currents or multiple diodes in parallel may be used.)
28,367
You will not find any 1N4008 because they are not made. And post #4 is incorrect about the scheme for diode numbering. And what is an "EHT" rectifier? Not familiar with that acronym.
28,367
hi,
Extra High Tension.
E
OK on "EHT", not a term I would use. That would be the second anode high voltage diode, often embedded into the horizontal output transformer. That would be a good alternative if it can be recovered. I have not tried to do that. Those devices seldom fail.
28,367
OK, I get the point. BUT for perhaps 40 years the 1N400n set only went up to 1N4007. So you got me with a new part.like
It is n that those will be among a stack of pieces left from projects completed a while ago.
DickCappels
Joined Aug 21, 2008
10,661
EHT is the thing in a CRT receiver or monitor that can cause one to do what one of my bosses used to refer to as "Do dah dance!"
If the subject diode needs to withstand 1655 volts. Whether one uses two 1N4008's or two 1N4007's in series the only effect would probably be cost and availability. Note that there are rectifiers, though not as cheap and the 1N400X series that are rated at 2 kV & up with faster reverse recovery times, not that you'd see any improvement at 50 or 60 Hz.
Reloadron
Joined Jan 15, 2015
7,953
The 1V2 has a voltage drop of 135 volts at 7mA. This may be an issue
I gave that some thought also. When replacing some of the old vacuum tubes or valves (for those across the pond) the forward voltage drop might be a consideration but the more I thought about it I doubt it matters much in this application, with a vacuum tube having a 6.6 KV inverse plate voltage. :)
Ron
