Replacing components
Zynch175
Joined Jul 20, 2017
11
I need to change a few blown components from a charger, but I can't seem to get the exact ones.
The MBR5200 diode with datasheet: https://www.diodes.com/assets/Datasheets/MBR5200.pdf
can I use this one?
http://www.tme.eu/sl/Document/b910c50b6b49fab4130a48499e482579/HER501-HER508-DTE.pdf
And also I have a resistor which in my opinion must be at least 1W or 2W it is 0,43Ohm 5% (yellow, orange, silver, gold) but what is the exact wattage the size is approximately 11x4,3mm.
Could someone tell me if the diode is good, and what wattage is the resistor if you could determine it.
Ylli
Joined Nov 13, 2015
1,092
HER503 - 508 should be usable. A 4 x 11 mm or 5 x 11 mm resistor is most likely a 1W, but if there is room replacing it with a 2W would not be a bad idea.
Zynch175
Joined Jul 20, 2017
11
Can you post some pictures of what you are working on?
It is a battery charger for Ryobi cordless tools.
Photos: https://app.box.com/s/1y3z0cwrmin4perh60tbqlnjdkvfa2as
The diodes are where there are two empty holes, and the resistor is behind the heatsink.
So I found some MBR5200 diodes (the exact ones) they are a bit pricey, but I will go with them, as for the resistors I just bought a few 1W and 2W resistors so I will see which ones I can fit in.
Zynch175
Joined Jul 20, 2017
11
I just tried to open the page in a few browsers and it opens correctly, so no idea as to why you can't open it (the link is to a folder with photos in my cloud storage)
