So a old but good drill of mine just went out it is a Makita BDF452. I replaced the brushes and that seemed to work but I am once again having a problem where it just stops working all of a sudden and the only thing that happens when I hit the switch is the led comes on. Ill leave it fora while come back and it will work again. The power seems to be generally lower than before I put new brushes in. Now The brushes are not the exact same ones that came out I took out 436 and puit back in a 440. The vendor said it worked on this model number. Does it matter that much, in a caliper its basically same size shape etc.
I am kinda at a loss of where to go next another snafu was I really didn't understand how it all mounted together on the inside and in my screwing with stuff I nocked one of the steel plates off the outer portion of the motor and bent it. I don't know if that can effect anything. Let me know if you want pictures. The entirety of the interior of the rear housing can be bought maybe something in that is broke. Kinda at a loss of what direction to go in next, any help appreciated.
