Thanks! That does make a difference. I have noticed if you really pour on the IPA it does help.Old school here, I still use thin rosin-core solder and a sharp tip to hand solder SMD parts on DIY prototypes and systems.
View attachment 249743View attachment 249744
Eutectic (Sn-Pb) solder is not a rarity in the industrial repair and manufacturing field.
The electronic ROHS is mainly about manufacturing commercial products. The industrial products I build use lead electronic solder because I want them to last and leaded products are much easier for hand soldering joint quality. In the last year I had a long discussion with the local OHA about our engineering soldering practices during a general inspection. I told them in no uncertain terms we would continue to use lead-based solder for repairs and for building systems for internal industrial use.
Back to cleaning.
Use the brush on the wet solvent then remove the mixture before it dries too much.
Back side residue cleaned
Fully cleaned and tested boards.
View attachment 249741View attachment 249742
By the way, what make and model is your inspection scope? It appears to give a nice clear up close view of the board on a nice large monitor.
