Removing an audible “pop” from a CMOS switch - Ramping Power?
rogs
Joined Aug 28, 2009
279
Have a read of this application note. What you want is called a "make before break" audio switch. They make some that are a direct replacement for the 4066.
The only 'noiseless' Maxim switches I've encountered to date are the 4910/11/12, which are not, of course, direct replacements for the 4066.
AFAIK, they're only available as surface mount?.....
I didn't realise they do a 'noiseless' audio DIL direct replacement for the 4066 as well....that's excellent news!
Do you have the part number?....
danalog
Joined May 8, 2012
19
Thanks! I am going to try to find the right make before break CMOS ad give it a go. I am also going to try the NP capacitors as well because I am the curious type and want to try all options for myself.
danalog
Joined May 8, 2012
19
I am looking at Maxim pages but I am having trouble finding much in through hole design. I tried tech support but got nowhere. Any suggestions for through hole IC's?
danalog
Joined May 8, 2012
19
I have tried the Non Polar Electrolytic Capacitors with 2.2μf and 4.7μf, I even tried 1μf's and 10μf's, but they are all still producing a pop.
Rogs was correct that...
"At best this will allow 'pops' of different volume, every time you switch. At worst, it will introduce distortion into the signal path."
With the NP's I am now getting varied "pops" with the signal change.
I am really having a problem finding a good thru hole IC, there has to be a few good DIP's that fit the bill.
rogs
Joined Aug 28, 2009
279
I don't think you are likely to find one - at least not a 4066 compatible one.....and I don't know of any other 'noiseless' ones.
Maybe someone else can come up with something?...
If you are still keen to switch your signal path, before the amplifier, take another look at Silonex opto coupled LDRs I linked to earlier. They will not introduce any distortion into your signal path, and you can make the switching silent.
You may need to experiemt a bit, to find the best way to effectively 'switch' your signal routing at such high impedance, by just using variable resistors, but that's what 'hobby' electronics is all about.... :)
danalog
Joined May 8, 2012
19
I don't really care if it is 4066 compatible chip as long as it can act in a similar way, i.e. SPDT style with two inputs each having it's own 2 outputs.
rogs
Joined Aug 28, 2009
279
74HC4016 (and 74HC4066) are higher speed versions of the standard 4016 and 4066 switches, and are designed to work from a 5 V supply.
They are much faster in operation than the 4016 or 4066 (not important in your application).
They will still 'pop', I'm afraid.
Looking again at your original drawing, you also need to consider that you are presenting CMOS inputs 'raw' to the outside world.
CMOS devices are very sensitive to ESD (static) damage, and I suspect that they would not last very long in a 'real world' environment, without some sort of buffer protection against static discharge.
Look again at some of the commercial 'stompbox' schematics. You'll not find CMOS switching directly on the inputs and outputs on any of them.
If you want to make a silent, reliable, signal router, you need to think in a different direction.....
Direct (mechanical) routing (either through a multipole footswitch, or via a relay) or LDRs, are both worth looking at....
danalog
Joined May 8, 2012
19
I don't mind going back to the beginning again because I want this circuit to perform flawlessly, transparently and with a simple design.
I do not want to go the mechanical route due to prior testing I have done with both multi pole stomp switches and mechanical relays. I found that they both can produce a pop under several conditions. I think I am going to jump into the FET switching concept like you referenced earlier.
I am also very interested in the optoisolator idea. I found a few that are actually not very expensive. Would this work for switching as well as the Audiohm series?
http://www.alliedelec.com/search/productdetail.aspx?SKU=70136794
rogs
Joined Aug 28, 2009
279
Yes, that should work fine. If you're going to stick to using the variable resistor passively you may need to experiment a bit, as I suggested before.
After all these are resistors, not switches.
Don't use a configuration that presents any significant resistive load to your guitar output. Passive guitar outputs need to look into high impedance inputs, or you will affect the tonal response.
R!f@@
Joined Apr 2, 2009
10,014
Tht's funny. Caps are there to block DC, and the pop is a DC signal decaying.
Is it not tht the pop is before the 4066 ?
rogs
Joined Aug 28, 2009
279
Have a quick read of the app note I linked to in post #5.
You cannot completely eliminate the pops from 4000 series CMOS gates. You cannot 'slow down' the gate transients.
You can make them 'smaller' or by ensuring there is no variable DC shift on input or output during switching - and capacitors can help achieve that.
They can also make them worse, if the DC charged states of the capacitors are allowed to vary.
Audioguru
Joined Dec 20, 2007
11,248
If you switch quickly during a program then the instantaneous level is DC which causes a POP.
You need to mute fairly slowly, switch slowly (ramping the control signal) during silence then slowly unmute.
rogs
Joined Aug 28, 2009
279
Which is of course exactly the reason you have problems with CMOS 4066. You can't 'get at' the gates, to slow down the gate switching time....
bertus
Joined Apr 5, 2008
23,027
When you have equal DC potentials on both sides of the 4066 switch, the "pop" will be lower.
The resistors can be in the range from 10 to 100K.
There will be no DC jumps on the capacitors on both sides.
R!f@@
Joined Apr 2, 2009
10,014
here's another thought.....Something I had in mind for future project of some kind
I will be using hermetically sealed relays specially made for audio switching.
I have seen this and I think it is much better than any other switch
Audioguru
Joined Dec 20, 2007
11,248
If you suddenly turn on or turn off a CD4066 with a fast pulse then some of the pulse capacitive-couples into the audio as a POP.
But if you slow down the rise and fall times of the pulse a little then nothing is coupled into the audio if the audio is muted during switching.
danalog
Joined May 8, 2012
19
Thank you Bertus, I tried this with 10k resistors and your tip immediately killed the pop in the switch!
What would be the difference in the circuit in respect to going lower with the 10k's or going higher as in the 100k's? I have tried them both and cannot tell an audible difference in the sounds overall tone or volume.
I was thinking that changing the size of the resistors would have changed the tone some, but now I am thinking that outside of balancing the DC level that the resistors do not color the sound. Is that a correct assumption?
0 PCB Layout , EDA & Simulations 4
