Relay for the first time, does this look about right?
Ali Afshar
Joined Aug 24, 2018
6
Hi everyone,
I'm using a relay for the first time and I am a bit confused. I copied some schematics from the internet, and this seems right with a relay and an optocoupler.
I am most worried if the direction across the relay 5 .... 2 matters and I am not sure I have it right.
Thanks!
ericgibbs
Joined Jan 29, 2010
21,542
hi Ali,
Welcome to AAC.
The Diode D1 is the correct direction.
The relay coil can be connected either way on a standard relay as shown in the circuit.
E
Ali Afshar
Joined Aug 24, 2018
6
Hi, sorry to not be clear. It's the combination of the coil and diode that I am worried about. Or perhaps the coil is bidirectional?
ericgibbs
Joined Jan 29, 2010
21,542
hi,
If there is no polarity coding marked near the pins on the base, ie: no + or - symbols, the coil can be connected either way.
When using a 'special' type of relay its a good idea to get the relay datasheet to check the pins.
The Cathode [ marked with a Bar ] of the suppression diode, always points to the positive supply end of the relay coil.
E
I've seen octal sockets marked + and - where polarity doesn't matter.
For most relays polarity doesn;t matter.
Latching relays, it does.
Relays with integral suppression diodes, it does.
In automotive relays, particularly the Bosch style, there is a "suggested" polarity. Some of these relays have an integral diode.
