Relay for Arduino Project
-live wire-
Joined Dec 22, 2017
959
I need a good relay for an Arduino project. Here are the requirements:
-It needs to be solid-state.
-It needs to be responsive and switch quickly.
-It cannot require too much current or require more than 5V on the input, as the Arduino I am using is incapable of delivering that. The less voltage and the less current needed, the better.
-It must have very low power losses on the outputs.
-It must be able to handle 2 amps at 31 volts, but ideally higher because of tolerances and component life.
-It would ideally have a normally closed pin as well as a normally open one.
-It should be under $20.
-It cannot be too hard to connect to my circuit (no very small pins close together), or too large.
If someone could suggest a good relay that fits the requirements, that would be great. Also, if I am asking too much of a solid-state relay, then please let me know and suggest an alternative.
BR-549
Joined Sep 22, 2013
4,928
What is the switching rate? Have you considered a conventional thru hole relay? Very reliable and tolerant.
-live wire-
Joined Dec 22, 2017
959
Using two relays instead would not be a problem, but I don't want it to be too expensive. So what are some good, reliable relays that I could use for my project?
dl324
Joined Mar 30, 2015
18,454
What are the drive characteristics of the Arduino and what is the power budget for the relay?
spinnaker
Joined Oct 29, 2009
7,830
Do you want it good or do you want it cheap??
I am perplexed as why you refuse to mention what you are trying to actually do. You might not even need relays at all.
-live wire-
Joined Dec 22, 2017
959
Is up to 1 or 2 megahertz realistic, or should I look for an alternative? There are multiple things I want to do with the arduino and the 31V power supply, some of which would require fast switching speeds.
panic mode
Joined Oct 10, 2011
5,210
SSR are faster than electromechanical relays but even so, 1-2MHz is unrealistic. operating times for 2A SSR are on the order of 1ms meaning that frequencies over 1kHz are going to be unlikely. to get to 1MHz, we are talking about three orders of magnitude.
