Hi guys, I'm new to the forum, so first lets say hi to everyone
I recently bought a "W1209 Temperature Control Switch"
What I'm not sure now is if I can use it on 220V. The Relay on it reads 20A 125AVC among other info. But also says it's a Songle and SRA-12VDC-AL
So I found the Datasheet online.
https://datasheet.lcsc.com/szlcsc/SRA-12VDC-AL_C86414.pdf
I believe from what I see on it, that it's totally OK to use with up to 250VAC
Can someone confirm if I am good to go?
Thanks a lot.
PS: I haven't tested for one of the uses I going to give it, if I even really need 220V, but just to be safe in case I use it on 220V for some other things.
Thanks a lot.
