Relatively Prime
zulfi100
Joined Jun 7, 2012
656
One method to find relative prime numbers for a given N is:
RP(55) = RP(5-1) * RP(11-1)
= 4 * 10
40.
Is the above a correct method, somebody please guide me.
Zulfi.
WBahn
Joined Mar 31, 2012
33,277
Ah, it sounded like you were saying that you were using that method to find a number that was relatively prime to 55, but I see that you meant that you were finding how many numbers are relatively prime to 55 -- also known as Euler's totient function. Yes, what you showed is correct in the special case of a number that is a product of prime numbers, none of which are repeated.
The Electrician
Joined Oct 9, 2007
2,986
= 4 * 10
40.
Zulfi.
Assuming that the function RP( ) is the Totient function, the method shown doesn't seem to work:
RP(55) = RP(5-1) * RP(11-1) needs to be RP(55) = (5-1) * (11-1)
Furthermore, not all numbers of the class described by WBahn: a "number that is a product of prime numbers, none of which are repeated. "
work with the method the TS describes:
WBahn
Joined Mar 31, 2012
33,277
I didn't look closely enough. I was too focused on the steps and not what was actually written.
You are correct, it should be
RP(p1·p2·...·pn) = RP(p1)·RP(p2)·...·RP(pn)
if all of the p's are prime.
WBahn
Joined Mar 31, 2012
33,277
I'm not following how this is a counter example since 15 is not prime, and so you have
EulerPhi[165] = Euler[15]*EulerPhi[11] = EulerPhi[3]*EulerPhi[5]*EulerPhi[11] = (3-1)(5-1)(11-1) = 2·4·10 = 80
The Electrician
Joined Oct 9, 2007
2,986
The TS showed a number (55) factored into two factors. He didn't say that the factors had to be individual prime factors of the starting number. I factored my example number (165) into two factors, one of which could be factored further, but nothing in post #1 said that the method being illustrated required it. It appeared that a procedure applied to the two factors would give the desired result. The method was not completely specified.
zulfi100
Joined Jun 7, 2012
656
phi(37) = 37-1 = 36
phi(21) is not a prime= phi (7) * phi(3) : Not both 7 & 3 are prime = 6 * 2 = 12
I think this is the example which I saw in the book. So 40 is correct.
Zulfi.
