Hi all
I have purchased a laminator today which I intend to put to use as the tool for toner transferring my PCB patterns to copper clad sheet.
First up 1.6mm copper clad fits
Secondly I have opened it up and figured out the wiring and what controls the temperature.
Thirdly For transferring toner to copper a temperature of between 135-165 degrees C is needed.
The picture, scuse the roughness, shows the wiring of the unit. Now what I plan on doing is changing the 2 thermal switches for a single 160degree C rated thermal switch.
I have temporarily removed the B145 thermal switch and run the unit to test it with a toner transfer and it does the job but obviously I need to regulate the temp.......... as it starts smoking otherwise
Is it OK to change the 2 existing for the 1? I have to confess to not quite understanding how they work within the circuit. One is marked B115 the other B145. But they are in parallel so I don't quite get how they function as a pair. Also the heated rollers don't seem to be in circuit at first glance but they get hot obviously and when the peak temp is reached the LED lights up.
Any guidance gratefully received
Fenris
Fenris
