Regulated power supply
NTCM
Joined Apr 17, 2013
8
Dear all
Could you please help as soon as possible
for the below project i need the circuit diagram and theory calculation
(Design and implement 8.2v Regulated power supply using full-wave bridge rectifier (use zener diode for voltage regulation)
#12
This isn't a free engineering service. It is rare that we work out a full schematic for anyone, especially in a manner of doing their homework for them.
33,211
Is there any particular format they we should use? Should we save you the hassle of turning it and just submit it directly to your instructor for you?
If you want "help", then you need to show YOUR efforts to solve YOUR homework problem (for which YOU will receive a grade and WE will receive NOTHING). If you put in an honest effort, you will find the people here will bend over backwards to help you find your way to a solution. But if you just want the work done for you, you will discover that this becomes a pretty harsh place.
33,211
Dears
Just i want to Guide me, support and how i will start from member experince
My "member experience" is telling me that you aren't interested in putting in any effort on your own and just want a handout. That doesn't get you far here.
You need to post SOME attempt at a solution. It doesn't have to be much. But keep in mind that we start from YOUR attempt, so the more effort you put into that the quicker things will get moving.
bountyhunter
Joined Sep 7, 2009
2,512
Hard to sympathize..... all you have to do is a Google search for power supply circuit, do a screen snag on the image and post that as a starting point.:p
NTCM
Joined Apr 17, 2013
8
after searching i connect the element as sequnace
the input is 220/240 v output 8.2v
1-Transformer (for step down)-2-Bridge diodes-3-Capacitor-4-zener diode
t06afre
Joined May 11, 2009
5,934
Should it not be a resistor in series with zener. If not the zener will go up in smoke ;) Again refer to your school books about this
33,211
This is not an adequate description of your circuit since there are numerous ways to connect them up. Please provide some kind of diagram. It doesn't have to be fancy. Paint will work just fine.
NTCM
Joined Apr 17, 2013
8
I hope to give me your opinion about the circuit i draw using multisim after reading the information from internet and i saw many diagram i you have any comments please advice (the Voutput 8.2 v using zener diode as regulater see the attachment
