REF102A
andriasm
Joined Aug 2, 2022
25
I need some similar option of REF102A, but I need with an output current bigger than 24 mA. Do you have some idea? It must be the same size
WBahn
Joined Mar 31, 2012
32,823
You should not be drawing any significant current from a voltage reference. It's a reference, not a power supply.
Look at the data sheet for the REF102A and you should find several options for supplying more current to the load while maintaining the voltage at the referenced level.
