If you make a virtual center for the filament winding you must disconnect the connection to V2 cathode. The, "usual" value is a pair of 100 ohm resistors.
Sounds like it's worth a go. 1/2 watt resistors should suffice, correct? Thanks!
While I'm in there, I'm thinking one other mod. The amp doesn't have a master volume control (and there's not really any room on the front panel for another potentiometer). I'm thinking of simply creating a "2-step" master volume with a small switch (already installed) so I can lower the input into V2 and turn the overall level up with the normal volume pot. The idea is turn up the volume/gain/distortion on V1 without raising the total volume. That way I can get a nice crunchy "tube tone" at a reasonable volume level, so my plan is split that 220k resistor before V2 into 2 resistors, such as a 160k and 56k, and use a small SPDT toggle to select either the full output of V1 or a smaller value from the voltage divider. my understanding is I need to cut the voltage by about 4 in order to reduce the volume by half.
