Recurrence for the running time of a recursive version of insertion sort
asilvester635
Joined Jan 26, 2017
73
I understand all the steps of the solution until the very last step (highlighted in yellow). It's not clear to me where we substitute equation (5) into. Click the link for the image.
WBahn
Joined Mar 31, 2012
33,178
Note that it says "the previous" and not "a previous".
They've omitted the step of generalizing eqn 8 to an expression in terms of T(n-k). Look at eqns 6, 7, 8 and see if you can see the pattern and write it as
T(n) = T(n-k) + ....
Then pick the value of k needed to reduce it to the for of the bottom equation.
asilvester635
Joined Jan 26, 2017
73
Click the image for my response.
WBahn
Joined Mar 31, 2012
33,178
You need to get the equation into the form
T(n) = T(1) + something
You have
T(n) = T(n-constant) + something
What does the constant need to be in order to make the second equation take on the form of the first?
asilvester635
Joined Jan 26, 2017
73
When n = 1, the constant needs to be 0 in order to get the equation into the form T(n) = T(1) + something.
Therefore T(1) = T(1-0) + something ----> T(1) = T(1) + something.
WBahn
Joined Mar 31, 2012
33,178
The left hand side of the final equation is not T(1), it is T(n).
If the constant is zero, then you have
T(n-0) = T(n) at the spot where you want T(1).
What do you need to subtract from 'n' to get '1'?
asilvester635
Joined Jan 26, 2017
73
So we are subtracting some constant 'c' from 'n' to get '1'. What value is 'n' in the first place? Right now it's just a variable, so I'm not sure what constant to pick.
WBahn
Joined Mar 31, 2012
33,178
You have
n - something
and you want it to equal 1
So you have
n - something = 1
What does something have to be equal to?
