Hi there, just joined as I usually post this kind of stuff on a significantly smaller IT related forum and get next to nothing in response. So expecting I'll probably post here quite a bit instead.
I have some power tool batteries that have been sitting for a while, the charger no longer charges them as they're too low voltage.
I have a variable power supply.
I know you can get 0V cell recovery chargers, and that BMS reign in the voltage and output to stop them from overcharging and blowing up.
Which brings me to my question, is there any safety issue with simply using my variable power supply to charge the individual cells in the pack to 3-3.2V (to avoid dismantling it), then shoving it back on the charger (under the protection of the BMS)?
My estimation is that even a dead cell shouldn't blow up with 3.2V applied.
And then when I've verified which cells are actually dead (if any) I'll think about dismantling and rebuilding with good cells.
