Rebock 2.2 edge treadmill stop working suddenly
home repair
Joined Apr 15, 2020
5
My treadmill stop working while i was using it for a gentile walk at 2.5 , I checked to see the inside and found fuse has blown.while it was in use I could smell burning. so when I pushed the belt it was free. any how checked the motor is working with my car batter. The lights on the dash bored are working.
Can any body help what could be wrong? and Is there a check for resister ? I do not see any burned parts any were. I have ordered some fuses in the meantime.
home repair
Joined Apr 15, 2020
5
Thank you Max I will have to wait till 21st to get my new fuse and try this.
How do I check the devices on the aluminum heat sink. and which devices ?
MaxHeadRoom
Joined Jul 18, 2013
30,807
There appears to be only two, check for short circuits for one, any other test may require removing them from the board, or just pick both up and replace them.
There should also be a bridge rectifier somewhere which should also be checked.
Max.
home repair
Joined Apr 15, 2020
5
Hi Max,
I finally got 10 am fuse and disconnected the motor put the fuse in and put on the power, the fuse was blown right away. now what can I do? I do not have enough know how to remove things from the board.
Busca en Google como checar un MOSFET y un puente de diodos con multímetro , pero en realidad si estás completamente en ceros mejor no lo intentes ..
