Reading LCD Schematic details
Link068
Joined Apr 10, 2017
31
I am about to make a foot print for an LCD but wanted to check first.
for connecting the 16 pins, correct me if I am wrong but the hole size is 1mm and the pad size is 2.54mm or less? and the spacing between each pad center is 38.1/16=2.38???
While I am at it, what does PTH stand for?
I know its simple but just want to double check.
Cheers
jpanhalt
Joined Jan 18, 2008
11,087
PTH = plated through hole
Pad width is 1.8 mm
Hole size is as you say, 1.0 mm ( a standard 0.025" square pin fits nicely)
Pitch between holes is 2.54 mm
This:
Means 15 spaces (for 16 pins) = 38.1 mm
27,501
It is also important, when the spacing is that close, to have the solder mask on the edges of the copper, to avoid bridging. Solder bridges reduce the production yield.
