Reading from Transistor Tester
Kelvin Lee
Joined Oct 22, 2018
111
Dear Sir/Madam,
Recently I bought a transistor tester, it helps me to check many unknown devices and show me the important information.
I tested with a LED and it reported Ir=4nA, C=23pF, what does it mean?
Best regards,
Kelvin.
Aleph(0)
Joined Mar 14, 2015
597
@Kelvin Lee
@Yaakov is totally correct:cool:! But just so u know, some ppl (and also datasheets) informally call reverse current _leakage current_:)
Also, cuz of parasitic effects, capacitance reading isn't vry useful w/o knowing test frequency (which should be specified in tester's manual otherwise u can just suss it out with TDO during test):)
Kelvin Lee
Joined Oct 22, 2018
111
Ir is Iᵣ, reverse current through the diode when it is reverse biased, that is hooked up "backwards".
C is capacitance, in this case 23 picofarads.
Thanks Yaakov, what is the use of reverse current? Is it the same as the current need to light up the LED?
Hypatia's Protege
Joined Mar 1, 2015
3,228
'Use' is inapplicable in this context -- Ir is merely a characteristic of semiconductor junctions - noted as a current under a specified reverse bias EMF < Ebr...--- Not to be confused with Zener (i.e. post-breakdown) current!
Illumination of an LED requires conduction under forward bias conditions! Typical I[fwd] falling in the range of 1-30 mA for discrete devices...
Best regards
HP
Hypatia's Protege
Joined Mar 1, 2015
3,228
Correct!:rolleyes: -- Such stems from the (IMO dubious) analogy of a semiconductor junction to a fluid-flow 'check valve'o_O
Absolutely! Then too, wave-shape (i.e. harmonic profile) must be taken into account! @Kelvin Lee If/where the reactance values are important, please heed @Aleph(0)'s advice and have a 'gander' at the test frequency and waveform!:)
Best regards
HP
dl324
Joined Mar 30, 2015
18,463
Does the documentation indicate the current for the Vf determination, or the voltage for the reverse current value? Without that information, measurements are only good for making comparative assessments.
Hypatia's Protege
Joined Mar 1, 2015
3,228
Just out of curiosity, does a pn junction not emit any photons due to reverse leakage?
Possessed of PEs in the optical range? - I very much doubt it?:confused: -- Of course some --as a practical matter trivial-- resistive heating (with secondary IR emission) will occur - but that's hardly the point... Intriguing idea, Tho...:)
Re: Junction capacitance:
Also the test bias voltage will play a big role
Indeed!:) -- 'Tis the 'Varactor' (i.e. 'Wooldridge') effect come a callin':) --- You getting this @Aleph(0):p
Very best regards
HP:)
dl324
Joined Mar 30, 2015
18,463
When my son was in middle school, or maybe grade school, I was trying to get him interested in electronics. I was showing him how a curve tracer worked and was using some LEDs to show him how brightness and forward voltage were affected by current.
I distinctly remember observing light being emitted from a reversed biased LED. I thought it odd at the time and have since seen numerous references stating that photons aren't emitted under reverse bias/leakage. I'll have to do some more experiments.
