RC circuit to fade in LED
snolan
Joined Apr 28, 2024
Hi everyone,
I want a circuit where I push a button and the LED fades in but goes out instantly when the button is released. Would this be a standard RC circuit with an LED in parallel across the capacitor?
38,644
An RC circuit will work for that but it takes more than just one R and one C.
For a smooth rise without a delay and instant off, it could be done with a SPDT PB switch, two capacitors, two resistors, and a diode.
How long do you want the fade to be?
What's the supply voltage and the LED current?
38,644
Only for about a second. It will be powered by two coin batteries
Below is the LTspice sim of an example circuit:
The green trace shows the LED current versus time after the PB is pressed.
C2 rapidly charges C1 to the LED's forward drop voltage after the PB is pressed, to avoid the delay that otherwise would occur for the capacitor to charge to that voltage.
The diode rapidly discharges the capacitor to ground when the SPDT PB is released.
