I am using the Raspberry Pi Codec Zero +Raspbery Pi4. I have followed all the instructions mentioned on this link.
https://www.raspberrypi.com/documentation/accessories/audio.html
However, it seems it still can not find the "RPI-code zero" drivers. I have updated the config.text file as instructed above including adding dtoverlay=rpi-codeczero, but I still see IQaudIODODEC on the drive
On the board itself, I have access to Stereo Aux IN or OUT but not onboard Mic or Ex Mic or Mono Speaker, and only can see the input.
Is there a bug with the drivers or any solution that you can instruct us with?
