Raspberry Pi 2 B screen adjust and build help
hoasov
Joined Mar 11, 2016
10
Hey all im new in this forum but i see videos from youtube about Raspberry Pi projects , I need your help with adjust my screen that i found in my home to the Raspberry Pi ,
that screen was from Digiframe that i dont need anymore and i want to adjust this screen to my project.
Before you start read i apologize on my bad english
My questions is :
1.a.) I need Driver Board for this screen that i can connect to the RPi no?
b.) if yes from where i can find the currect driver? (i need hdmi input for the RPI hdmi)
c.) if no what should i do to connect this to RPi?
(the screen is HITACHI TX26D01VM1CAA as you can see on the pictures)
2.a.) To the screen i need to connect two lamps invertes (TAKAO-CA003 as you see on the pictures)
b.) For what is this?
c.) How much Voltage and Amper imput i need to give that?
d.) I can use gpio of RPI to connect that and save the another transformer (one transformer is for the driver of the screen)? OR i can use USB from RPI to the imput ? OR i can use the driver board to connect this ?
3.a.) After all finish with the screen issues i need to run some commands on the RPI for adjust and confirm the screen on RPI?
the pictures :
http://postimg.org/gallery/hvpnneze/
20160305_110034.jpg 20160305_110057.jpg 20160305_110109.jpg 20160305_110225.jpg
