I did what they said, but I don't have permission to write, so even if I write, it doesn't record. If there is a python version that will support firebase you know instead, if I install it, will Raspberry pi have a connection with firebase after the command screen?It depends where your file (python script) is saved. You may have to open the script by navigating to the working directory where that script is saved. The use the command...
sudo nano yourPythonScript.py
then use the arrow keys to navigate to the row of the text file, delete with the backspace key and type the line I gave you.
thenhold ctl key + x key,
Then it will ask you to save, hit “y” to save as the same file name.
by Jake Hertz
by Jeff Child
by Jake Hertz
by Aaron Carman
