My company uses electronics, kinetics and sensors to make modern art installations.
I have a lingering problem with a piece where we levitate ping pong balls in glass tubes using programmed computer fans. We animate them into rolling sine waves etc.
We achieve precise placement by repurposing a laser range finder and aiming it from the underside up towards the ball. This information is then fed back to correlate with the intended data value in our programming to place it precisely where we want it to be. This all works perfectly.
The problem lies in the fact that all of these tubes are illuminated by an LED from above.
We alternate the colors with green and white leds. These are highly focused using glass lenses that brightly illuminate the ball. The mechanism works perfectly for the green led light but the laser range finder misreads on the balls illuminated on the white light. This made us deduce that it had something to do with the spectrum of light disrupting the laser. This causes the balls to "hiccup" or jump as they reach the upper half of the glass tube. My theory is that the light intensity through the ball, or even bouncing around is disrupting the light from the laser reflecting back to the sensor on the rangefinder.
In the link I attached you can see that the range finder laser's wavelength is 635 nanometers.
http://www.jrtsensor.com/sale-11893...m-support-single-continuous-measure-mode.html
The led spectrum emits a wavelength in this range as you can see in link.
https://www.cree.com/led-components/media/documents/XLampXPG2.pdf
Troubleshooting and solving this problem has been difficult. Here are a few things I have tried to circumvent this problem all to no avail:
Dimming the intensity (brightness) of the light to 50% power allows it to function, but there is little point in illuminating in that event.
Adding a polarization filter on the lens of the led individually.
Adding a polarization filter on the reflective lens of the rangefinder.
Adding a polarization filter to both.
Un focusing the light.
Testing with red, green and blue filters on the reflective lens of the rangefinder.
I would greatly appreciate any ideas on way to filter these frequencies out without a highly expensive or large filter. Or point me to the right place to ask this question.
