'Radio'control submarines...
Externet
Joined Nov 29, 2005
2,672
Hi.
How are the submarines commanded ? Is it <100KHz or ultrasonics ? What if you want wireless video return ? Is there any first-person-view FPV submarine ?
ArakelTheDragon
Joined Nov 18, 2016
1,366
You can not emit or pass radio waves through water, receive or transmit. You need a periscope which is an antenna that works on a certain depth, but no more.
ArakelTheDragon
Joined Nov 18, 2016
1,366
The submarine has a built in periscope that works on a certain depth. They are tricking you with this. The most accurate statement is "you need a periscope which works on a certain depth". You can not call it "no periscope".
I don't offend both of you, I appreciate that you don't offend me either.
Alec_t
Joined Sep 17, 2013
15,156
The lower the frequency the longer the wavelength and hence the bigger the antenna needed for a given signal strength. Antenna size becomes unmanageably large for anything other than short range transmission in water.
AlbertHall
Joined Jun 4, 2014
12,652
How will the signal be received or transmitted? is the table you give without an antenna(periscope=antenna)?
Transmitted and received by standard model control equipment, with the antenna on or in the model.
With say 27MHz you can't go very deep but you really don't want to - if you can't see it you can't control it.
Externet
Joined Nov 29, 2005
2,672
The wavelength of radio frequencies is different in water than it is in air. Uses much, much shorter antennas.
Water is a very lossy medium, but not a impassable medium. Never had a submarine 'radio'control, that is why am asking how they do it, if they do it.
Telemetry modem:
ArakelTheDragon
Joined Nov 18, 2016
1,366
They don't do it. You are describing exactly the same a periscope on a certain depth, thats why in movies they say go to periscope depth. This is just a trick saying "no periscope".
Externet
Joined Nov 29, 2005
2,672
For proper Tx/Rx antennas submerged, without the extra loss of air-to-water-to-air refractive boundary loss, range is better. This is not about dipping in water a vulgar collapsible rod antenna.
Another way is optical. Blue led arrays/photodiodes. Perhaps that is what they use, if they do it ?
WBahn
Joined Mar 31, 2012
33,122
Simply, factually not true.
Read up on ELF communications which are capable of communicating (one-way) with submarines at their operating depths with no antenna periscope or buoy. ELF waves can penetrate several hundred meters into the ocean and, in air, have negligible attenuation making it so that a single transmitter can communicated with submerged submarines anywhere in the world with only about 8 W of radiated power. The down side is that it takes a few megawatts of input power to achieve that.
oz93666
Joined Sep 7, 2010
742
Submarines offer great possibilities because they can be relatively small and support great weight ...
Why bother with RC ? You could easily build one big enough to get in yourself.
BR-549 General Science, Physics & Math 7
Similar threads
Chain Guns on Submarines
