I am trying to finish the assembly of the semiconductor radiation analyzer that I described here:
https://hackaday.io/project/159909-gamma-pin-semiconductor-radiation-detector
Unfortunately there appears to be a problem with the crosstalk in my project.
The comparator circuit is designed to detect positive pulses. The 3-stage preamplifier conditions the signal, while the last op amp is used as a voltage subtractor. By driving the subtractor with an DAC I set noise level to be just below the ground so that only the pulses generated by radiation are measured. Then the signal is delivered to the comparator which should trigger the clamp of the peak detector, but instead of single pulses the comparator starts to generate a rectangular wave. The whole circuit is very sensitive to any signals and goes nuts.
I used Tina-TI simulations to get the hysteresis loop of about 1mV. Increasing the hysteresis in reality leads only to change of the oscillation frequency. I have checked it with a source, and even with the signal level set quite low a single pulse still triggers the comparator to oscillation.
Is there a solution to this problem or it has to do something with the board design?
