#12 - there is a starter solonid. There is a starter switch. Not sure what that has to do with it though.Thanks, kermit. It's nice to feel welcome.
As for bksmith, if you really don't want to carry two of the much lighter lithium batteries, and you don't want to use a 3 ounce starter switch off a lawn tractor, a diode will work to keep an external starter battery from exploding the lithium fan/pump battery. Nerds like us don't understand why you want to create such seemingly artificial limits for your self, but we can name a diode.
Watch Kermit. He's on the job.
I have an off-site obligation to work on right now.
I understand how the two separate battery system would work, and help the situation. It's just a lot more in $Using a starter switch will allow a second battery to start your motor and not be connected to the fan/pump battery.
It would be best to put a second diode on the on-board battery to prevent the lithium battery from charging the on-board battery.http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2197628_-1
Oh, and be sure your off board battery has a higher voltage thsn the lithium, or it will try to charge your off board aux. battery.
You're right Kermit. I'll wire up a simple SPDT switch and run a small plug to the booster battery to run the pumps and fans while in grid - and flip it to run them from the onboard battery when on track. the simple answer is usually the right answer, right?now your back where I was suggesting before. Instead of a relay, just have a fuse panel with two positions. one for onboard battery ops and one for aux battery. Pull the fuse out of one spot and plug 'er in to the other depending on which bsttery you want connected. simple operation principle and if you only have ONE fuse and two sockets you can never have both systems connected at the same time. Fool proof.
| Thread starter | Similar threads | Forum | Replies | Date |
| E | Line-level microphone ADC with onboard DSP, I2S output, and graphical tuning software? | Analog & Mixed-Signal Design | 6 |
