Quick Thevinin Question
Digit0001
Joined Mar 28, 2010
100
Hi
Can someone tell me how would i do this question
I have tried to use a nodal analysis but still incorrect answer
P.S
Jony130
Joined Feb 17, 2009
5,599
First you need to find voltage across RL when the load is disconnect.
The open circuit voltage Vab = Vth
The second step is to find the current flowing from a to b when a & b are shorted together.
And then Rth = Vth/Isc
So know sow as your solution
Digit0001
Joined Mar 28, 2010
100
ok for Vth i get
(9-Va)/2 = 3Vx-Va
2(2Va) = 9-Va
4Va = 9-Va
5Va = 9
Va = Vth = 9/5
Then when i find In = (33/6)/4
so R = Vth/In = (9/5)/(In) = 4.4 ohms
What is wrong?
jegues
Joined Sep 13, 2010
733
ok for Vth i get
(9-Va)/2 = 3Vx-Va
2(2Va) = 9-Va
4Va = 9-Va
5Va = 9
Va = Vth = 9/5
What is wrong?
You wrote your KCL(or nodal analysis) incorrectly,
You wrote a "current entering the node = the other current entering the node."
Just write a simple KVL around the loop and express Vx in terms of the current flowing, solve Vab.
Jony130
Joined Feb 17, 2009
5,599
Simply nodal equation
(9-Va)/2 + 3Vx-Va = 0
Or we can write one equation like this
I = (9V - 3Vx) / ( 2Ω + 1Ω) = ( 9V - 3Vx)/3Ω
I = (9V - 3(2Ω*I))/3 = (9V - 6I)/3
I = (3A - 2I)
3I = 3A
I = 3A/3 = 1A
And Vx = 3*(1A*2Ω) = 6V
Vth = Vx + 1A*1Ω = 7V
