Quick question regarding circuit board artwork
electrojim
Joined Jun 3, 2009
20
Hi, all,
I'm just finishing-up a "build it" article for a magazine, and want to know the best way to include circuit board artwork. The article will link to a site that will make all Gerber files available, but for those who make their own boards in the kitchen, I wanted to make sure that I include the right 1:1 artwork as part of the article itself. Questions: 1) is 1:1 (actual size) the right scale for those who use laser printers and iron-on resist; 2) is the proper image a black board with white pads and traces, or other way around?
Thanks much!
JohnInTX
Joined Jun 26, 2012
4,787
I would think 1:1. Include dimension lines in both X and Y directions exactly 1" (or longer if possible) just outside the board outline so that the user can test print and scale it to see if they have to make adjustments to the printer scale factors.
As for 2), I don't know but most mag. articles I see are black lines on white. If the resist requires the negative, any photo editing software can do that easily.
Several members here roll their own and will probably weigh in. Wendy has recently posted a complete procedure in the Completed Projects section here.
Good luck.
12,273
If you are posting only one image, I would make it black traces on white bare space. But you're not competing for column inches in a print magazine. It's an online file - make both polarities and post both. A TIFF or GIF image will not exhibit ringing around the transition areas the way JPG and other lossy image formats do.
ErnieM
Joined Apr 24, 2011
8,415
Why not ask the magazine where your article will be published? I am sure they have guidelines for all of this.
As far as the roll your own guys go, I would be quite surprised if they cannot handle Gerber files, as they are the primary means to convey PCB information.
dl324
Joined Mar 30, 2015
18,466
Scaling and reversing shouldn't be much of a problem for any DIYer, but I'd do actual size and black for copper.
18,164
If the publisher can't advise you, at least add in reference alignment marks for the end user, so they can scale accurately using the marks. These might be an "X" in each corner, with instructions giving dimensions between the X's.
electrojim
Joined Jun 3, 2009
20
Thanks to all for good information. I'll default to 1:1 with black traces on a white background, but will defer to the magazine, which doubtless has its own preferences.
Please make sure that the PCB is accurate captioned.
e.g. "solder side, view from component side". Poor me did a mirror image of a layout. Very lucky for me, I was able to use it . NPN's and PNP's switched and the bias regulator needed some manual re-routing.
