Quick and dirty conversion from 12v DC to 6v DC?
Blank_Stare
Joined Jul 29, 2017
44
I **think** it should be as easy as placing a couple of resisters inline, between the car battery, and the 6v DC device I want to power. (A Trail Cam)
Would someone be so kind as to tell me if I am correct, and exactly which resisters to buy, please?
Also, I think the two resisters have to be placed in opposite directions (assuming they are soldered into the wiring, side by side,) but I'm not 100% sure of that.
I probably don't need a diagram, just a few words to clarify things. Knowing exactly which resisters to buy would be crucial, however.
be80be
Joined Jul 5, 2008
2,395
What you thinking is not going to work it is called a voltage divider.
What You need is lm7806 or a lm7805 and a diode and 2 caps.
dl324
Joined Mar 30, 2015
18,476
Think again. We typically run 10X the load current in the divider, so whether or not it's practical depends on the load current.
The resistors would be placed in series and they have no polarity.
You'd probably be better off getting a 6V regulator and a couple caps.
ian field
Joined Oct 27, 2012
6,536
You have to factor your load in when calculating values for a voltage divider. A Zener shunt regulator and dropper resistor behaves more predictably. Everyone who suggested 3-terminal regulators are on the right track - as long as your load doesn't need more than 1A.
The application notes describe how to increase current handling with an external pass transistor.
There are (allegedly) plug in replacement SMPSU 3-terminal regulators that can handle more current - but I haven't actually seen them offered for sale yet.
