Quick 9v power question
Fastmerc
Joined Feb 20, 2015
27
For a quick little Sunday project, I just took an old pair of powered computer speakers and made a little guitar amp out of it by adding a 1/4 input jack. It is powered by a 9V ac adapter. I wanted to also make it portable so I soldered in a 9volt batter clip directly to the ac adapter jack lugs. My question is do I need to unplug the 9 volt battery if I am using the adapter to power the speakers?
#12
Probably. Wall warts are notoriously unregulated. They would likely try to charge the battery. That's bad unless the battery is rechargable, and if it is, it needs a regulator for the charging current.
There is a way to use the power jack to automatically disconnect the battery when you plug in.
Robartes
Joined Oct 1, 2014
57
Yes. If you don't, you will have whichever of the battery or the adapter is at the highest voltage trying to push current into the other one. If you don't want to unplug the battery every time, you can build a simple switch with a FET or a transistor BJT.
Update: or you could follow #12's even better suggestion to automate the switching
Fastmerc
Joined Feb 20, 2015
27
I know I could just mount the batter on the outside of the speaker so I could easily unplug it if I need to or I could add a little mini switch to the case, is there another way?
#12
There is also the idea that TS said, "AC adapter". Those don't mix at all with batteries! :eek:
Does that mean AC input or AC output?
Fastmerc
Joined Feb 20, 2015
27
How would I do the automated switch?
Robartes
Joined Oct 1, 2014
57
I'm assuming your AC adapter outputs DC with positive on the center pin? In that case, your circuit should work.
Update: that's wrong. See below.
Robartes
Joined Oct 1, 2014
57
Additionally, are you sure the adapter outputs DC? The first thing after the connector on the PCB seems to be a bridge rectifier, which suggests AC.
30,845
Yes the input socket goes to the bridge, at least it will be steered to the correct polarity via the bridge.
Just that you will get ~ 1.5v drop over the diodes.
38,858
Note that a standard 9V transistor battery will likely not last long (perhaps a few hours for an alkaline type) in powering your amp.
