question on Time Delay circuit from Art of Electronics
tash13
Joined Oct 1, 2021
I have few questions on above excerpt from the book:
On the highlighted section, author mentions about circuit loading. I know circuit loading can be an issue with voltage divider, how is that a concern here?
Another question, Does the capacitor has to be fully charged before it starts discharging? what happens when the capacitor is fully charged and circuit is still connected to a voltage source?
ericgibbs
Joined Jan 29, 2010
21,567
Hi tash,
Consider the source impedance was say 15K, then the TC of the circuit would be doubled.
The Low output impedance of the 1st buffer adds little to the delay period.
E
ericgibbs
Joined Jan 29, 2010
21,567
Hi tash.
The circuit is a DC edge time delay, so if the input stays High so will the Output after the TC delay period has been exceeded.
When the input goes low, the low impedance of the 1st stage will quickly discharge the cap.
E
dl324
Joined Mar 30, 2015
18,454
Since most signal sources aren't ideal, they have a non-zero output impedance. That will act like a voltage divider.
The buffer has a high input impedance and a low output impedance.
No, but the R and C values would be chosen to give the cap time to charge and discharge enough to give the desired edge delays.
It stops charging. The book said to assume that the threshold voltage was Vcc/2. Once the input gets to that voltage, the buffer output is at Vcc.
