Question on Speed Control vs Torque Control
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
I'm controlling a Permanent Magnet DC motor with PWM for a treadmill. I'm using a reflective sensor with 6 pulses per rev to get a speed feedback. So I'm actually doing "speed control" directly, but not "torque control". So I have two specific questions:
1- Do I need direct torque control for this application by measuring the current? Or a combination of speed and torque control where a cascade PI is needed?
2- Do I strictly need to know the DC motor parameters (R, L, K, J, B) in order to do speed control?
It's okay I can vary the speed by changing the duty cycle. It works. But, beyond a simple analogy of pulse-width-modulation, I know it should be a whole lot more complicated than that.
MaxHeadRoom
Joined Jul 18, 2013
30,723
Most T.M. controllers such as the MC60 and MC2100 just use a simple motor current feedback monitoring drop across a series resistor. Any opto is usually used for display purposes.
I have been experimenting with simple speed control by constantly monitoring pulses and correcting this way.
Max.
Georacer
Joined Nov 25, 2009
5,182
I'd say that measuring current in a DC motor is kinda equivalent to the position derivative, so you could use this measurement if you want to do the "D" part of a PID controller.
But that's largely superfluous for your application.
Joined Oct 21, 2015
728
What about the motor parameters (R, L, K, J, B)? Are they relevant in this application? I think they're not. In order to take those parameters into account I would also have to take into account the whole system characterisitc, i.e, belt, mechanical characteristic, etc , not only the motor, if I would like to know the system transfer function.
