Question about using the TXB0102 level shift
Jassper
Joined Sep 24, 2008
103
Need to shift 3.3v to 5v TTL and space is a min. I'm using the TXB0102 to do this. I already have the 5v for Vccb, any pitfalls to be aware of using a V-divider to power the Vcca 3.3v side or should I add a 3.3v voltage regulator?
ElectricSpidey
Joined Dec 2, 2017
3,359
Use a regulator.
The voltage output from the divider will change every time the load changes.
Voltage dividers are used to provide a reverence voltage to a high impedance input, and do not perform properly when having to drive a load.
Jassper
Joined Sep 24, 2008
103
I kinda figured but was hoping to get away with it on a small load.
Why don't you have 3.3V?
It's a small board and space is a premium, was hoping to get away from adding a second regulator. The screen is 5v/5v TTL and the micro controller is 5v Vcc, but it's TX/RX is 3.3v level.
I'm using the OKI-78SR 5V to power the screen and the Micro as it doesn't require any additional components, so no 3.3v available. There is a different Micro controller with the same footprint I can use that is 5v TTL so I will probably switch to that.
ronsimpson
Joined Oct 7, 2019
4,823
It is not clear how much current draw on pin 3. It depends on the load. And data speed.
R1=1k gives you 1.7mA max to IC1. R2 change to a 3.3V Zener. C2= large bypass cap.
ElectricSpidey
Joined Dec 2, 2017
3,359
It's always been my impression that 10mA is the typical minimum current needed to maintain the Zener voltage. (VZ)
I could be wrong...it wouldn't be the first time.
Personally, I would use the minimum current in the data sheet and add the load current then calculate the resistor from that.
ronsimpson
Joined Oct 7, 2019
4,823
I picked a 100mW Zener at random. At 3.3V they are not good as can be seen by the curves. The curves are flat above 5V. This diode was tested at the factory at 5mA. Most ate tested at 10mA as you know. The high current diodes are tested at more current. I think it takes 2mA to get 3.0V from this diode. I agree the 1.7mA I proposed is low. 470 ohm resistor will move the current to 3.4mA. & 3.2V
The IC probably does not care exactly what the voltage is.
