Question about turning on a relay with pullup resistor
hunterage2000
Joined May 2, 2010
487
Hi all,
I have a circuit that uses a SIPO shift reg and each output Q7 - Q0 is pulled up and goes to a schmitt inverter.
The output of the inverter should turn on and off a 12V relay.
Is this possible because I can't get this to work? am I missing something.
I have a 5V relay and this is working.
Alec_t
Joined Sep 17, 2013
15,158
What inverter are you using? Applying 12V via the relay coil to an inverter with a 5V supply is likely to fry the inverter.
You could use a NPN transistor (or logic-level MOSFET) instead of the inverter. Drive the NPN base with the SR output, via a current-limiting resistor.
