Question about RFC choke in Colpitts Oscillator
silv3r.m00n
Joined Apr 15, 2010
70
I am fiddling with this simple colpitts oscillator:
It has a RFC choke in the collector.
I am trying to understand how it works. I assume that :
1. The choke provides LOW impedance path to DC hence allowing quiescent current or operating current for the transistor.
2. The choke acts as high impedance for the ac oscillations at high frequency hence provides gain by acting as high collector resistance for the AC.
Are the above assumptions correct ? or is there more to it ?
However, the RFC choke is an inductor and causes phase shift between the voltage and current.
So with the RFC choke the amplifier is not a strictly 180 degree inverting amplifier ? OR is it ?
If rfc cause phase shift the loop phase shift will not be 0, and the oscillations should not work.
But the above circuit works fine, producing oscillations around 175 Khz.
Am I missing something ?
Marley
Joined Apr 4, 2016
519
You are absolutely correct. L1 provides a DC path but blocks the AC signal.
I would expect its inductance to be considerably higher than the inductance of L2.
If everything works - well done!
silv3r.m00n
Joined Apr 15, 2010
70
but doesn't L1, the rfc choke in collector cause 90 degrees phase shift between v and i, during amplification ?
how is the oscillator able to maintain a loop phase shift of 0/360 deg ?
LvW
Joined Jun 13, 2013
2,031
in both oscillators, the v and i are out of phase by about 90 degrees.
so how is the oscillator able to maintain 0/360 deg loop phase ?
the tank is 180 deg diff, the amplifier is about 90, so total is 270 only.
Well, the influence of the inductor L1 ist not so strong as you think because L1 is to be considered in parallel to the remaining feedback path. More than that, the transistor is a REAL current source with a finite source resistor r_out.
The frequency determining feedback path is 3rd-order lowpass - see the ladder structure r_out - C2 - L2 - C4.
There is one single frequency, where the phase shift crosses the (-180) deg line and this frequency - together with the phase inversion of the transistor stage - can fulfill the oscillation condition.
silv3r.m00n
Joined Apr 15, 2010
70
so it finds a frequency which satisfies the loop condition of 0/360 degree phase shift.
the RFC choke L1 (Rout) in collector is also a part of the frequency determining network
which does not look neat. calculating the frequency by hand gets difficult then.
it affects both the gain and the frequency.
also this circuit has considerable distortion and difficult to modify.
i wonder why it is mentioned in so many websites and books.
LvW
Joined Jun 13, 2013
2,031
Yes - you are right, "calculating the frequency by hand gets difficult".
More than that, in addition to L1 also the output resistance r-out as well as the input resistance at the base (both just roughly known) are part of the frequency-determining feedback path.
I only can guess why its mentioned so very often - perhaps because it is one of the classical oscillators ?
It certainly has the disadvantage that it will not be possible to tune the frequency without touching the loop gain and with it the oscillation condition.
There are other circuits which allow separate (orthogonal) frequency tuning without touching the oscillation condition.
