Question about LTSpice's .lib file
BlackMelon
Joined Mar 19, 2015
173
Dear All,
I am using the attached diacs.lib from STMicroelectronics. However, there is a warning on the image file.
After I inspected the .lib file, I deleted "*{Tr}" from this line: R_R1 N02098 TRG 1.462*{Tr}, and the simulation worked fine.
It seems like the LTSpice doesn't recognize the "*" sign. However, doing so will make R1 be independent from the rise time (Tr).
I searched the .lib file elsewhere, but can't find R1. So, I would like to know what should I do with the parameter R1?
Sincerely,
BlackMelon
ericgibbs
Joined Jan 29, 2010
21,649
hi BM,
In LTS the '*' is a Comment marker.
For R1 why don't you find the Tr for the device, multiply by 1.462 and enter the value in uS into the Lib file.
Save the Lib and restart LTS.
E
Update:
Checking thru that Lib.
+Tr=0.342
1.462*0.342 = 0.500004
So.
R_R1 N02098 TRG 0.500004
Alec_t
Joined Sep 17, 2013
15,167
Yes, if it starts a line.
It's also the floating point multiplication symbol, so the 1.462*{Tr} looks valid to me, providing Tr has been defined as a parameter.
Edit: Oops. My bad. It's not valid, but {1.462*Tr} is.
eetech00
Joined Jun 8, 2013
4,750
Dear All,
Sincerely,
BlackMelon
You shouldn't change anything. You are using the wrong model.
The DIAC model is a template subckt that is used by the "real" models tuned for specific devices.
Do not use the DIAC model.
Use one of the subckt model names defined under the description "Standard DIACs definition", like "DBT3G" for example.
