Question about linear voltage supply transformers and current
hunterage2000
Joined May 2, 2010
487
If you have a chassis mount transformer with specs:
Primary V = 230Vrms
Secondary V = 24Vrms
S = 6VA
Does this mean the maximum rms current that can flow through the transformer is 250mArms?
Just wondered if you used this transformer to get a rectifed 25.9V DC input to a LM317 linear regulator. you could only get a maximum load current of 250mA DC before the output voltage drops?
MaxHeadRoom
Joined Jul 18, 2013
30,815
The Va of the transformer applies to both primary and secondary, IOW if you have a 6va version then yes, the load placed on the secondary is limited to 250ma.
Max.
hunterage2000
Joined May 2, 2010
487
I see. I'll get a higher VA rated transformer. Anyone know of any good sources for variable linear power supplies i.e books, sites etc?
dl324
Joined Mar 30, 2015
18,473
Datasheets usually have application suggestions.
The National Semiconductor Voltage Regulator handbook has a wealth of information. Including how your choice of rectification/filtering will impact transformer current requirement:
38,832
The VA rating is not where the voltage drops, since there is typically a 10-15% voltage drop from no-load to full-load due to winding resistance.
The VA rating is determined by the heating of the transformer.
Beyond that VA rating the transformer can overheat.
