Question about High Voltage Grounding
Gear_Clinkz
Joined May 25, 2013
16
I'm making a high voltage power supply using a ZVS driver and a flyback transformer.
Should I connect one of the output cables of the flyback to the earth ground? Or should I have two HV leads coming out of my power supply?
I don't care whether the output is floating or mains earth referenced, I just want it to be safe.
Thanks in advance.
Dodgydave
Joined Jun 22, 2012
11,395
Why are you bothered about it being safe when it's High Voltage ⚡, if it's not being powered by mains voltage, it doesn't matter.
What is it being used for?
Gear_Clinkz
Joined May 25, 2013
16
It's mains powered and I have the earth ground and the ground from my 50V transformer (after the rectifier bridge) both hooked to the metal casing. Should i connect the Flyback ground to the metal case too?
DickCappels
Joined Aug 21, 2008
10,661
Probably, yes. At least that way you know where the output is with respect to ground and grounding the circuit will reduce the chance that the return (ground) to the power supply will float at some large AC voltage because of leakage.
Put another way, even if the circuit on the secondary of your transformer is isolated from the power line, there is still leakage that might cause an annoying shock, affect some delicate measurement, or even destroy a static sensitive component. Earthing (grounding) the second removes this risk.
Gear_Clinkz
Joined May 25, 2013
16
Thank you for your answer! I'll ground it and hope no weird things happen.
