Question about Class AB output stage
ian field
Joined Oct 27, 2012
6,539
The figure attached shows a class AB output stage. From this circuit can be derived the equation
IN x IP = IQ^2
From this equation it is correct to state that the transistor will never cut off?
Most people don't do it that way, mostly because of temperature coefficients.
Generally, you'd use a self compensating arrangement with low value emitter resistors.
diodes of the same semiconductor material, preferably clamped to the same heatsink can be used to provide the reference Vbe for each transistor. You can vary the diode bias current for a bit of wiggle room to clean up any lingering crossover distortion.
Daniel Pereira Carvalho
Joined Oct 10, 2016
Hi Ian,
Thanks for the anwser.
I'm aware that this circuit is can't be used in real devices. I'm using it to simplify the operation analysis.
