Question about capacitor voltage ?
Status
Not open for further replies.
qwertyqwq
Joined Jul 11, 2019
20
hi folks !
Nowadays im building a ac/dc full bridge rectifier. As you know , after the full brüdge rectifier , for increase ripple voltage im using couple of elect. capacitor. Still there are some ripple factor on my dc voltage. I should usr more capacitor on it but i dont have enough.
My main ac voltage is single phase and 220v (rms) 50hz. The problem is my capacitors are 200v. I need 400v capacitor i know but idont have.
Is there any method to use 200v capacitor rather than 400v capacitors ??
And secondly , can those capacitors limits current ??
Thanks QwQ.
oz93666
Joined Sep 7, 2010
742
You can put capacitors in series ... suppose you have Two 200V @ 200uF each ... wired in series will give you One cap ..400V @ 100uF .
If electrolytic you must connect +ve of one cap to the -ve of the other .
AlbertHall
Joined Jun 4, 2014
12,654
Discussion of transformerless power supplies is forbidden on here for safety reasons.
From the user agreement:
  1. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Any kind of jammers (ie - Phone jammers)
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
