Question about being killed with electricity...
steev
Joined Jun 12, 2011
7
Hi Everyone,
I've got a very basic knowledge of electricity so please excuse this question!!!
Someone once told me that "amps kill, volts don't"
Is that true?
I suppose they meant that - in theory - you could have a mains 110v or 220v / 1amp running through your body and it wouldn't kill, but 110v/220v at, say, 50 amps would kill...?
Or 4000v at 1amp wouldn't but 4000v at, say, 25 amps would kill.
not that I want to find out.......
These are only examples and I realise they're not practical mains power supply types!!!!
Steve
Wendy
Joined Mar 24, 2008
23,797
True, but misleading. Volts breakdown skin resistance, and the amps finish you off. You can be knocked on your butt with 12VDC. If the current was introduced through the skin (say with needles) it would likely be fatal if directed through the heart. Current path is also important.
So if you run into a low voltage system with lots of amps you are likely safe, if it is a high voltage system with low current it can be lethal (it only takes 10ma or so to kill).
This subject comes up every so often.
cjdelphi
Joined Mar 26, 2009
272
I once had a 380v disposable flash capacitor discharge (freshly charged too) on me on 1 hand and discharged through my other, yes 2 sparks almost at the same time, weird sensation followed by a numbness in the arm that got zapped, it felt like a very quick burn, it left to red dots/puncture holes... :)
Anyway This got me thinking, I got out the multimeter, when I grip hard, I get the resistance down to about 160k ohms, loose grip, 250kohms... my hands are very dry, it's also winter and im a bit cold too.. so I just wrote a quick 8 line program to output, and the figures don't make much sense, do i have my maths wrong?...
1volts, Skin Resistance: 160kohms, Potential Current Flowing: 6.25E-6ma
8volts, Skin Resistance: 160kohms, Potential Current Flowing: 5E-5ma
15volts, Skin Resistance: 160kohms, Potential Current Flowing: 9.375E-5ma
22volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0001375ma
29volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00018125ma
36volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.000225ma
43volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00026875ma
50volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0003125ma
57volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00035625ma
64volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0004ma
71volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00044375ma
78volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0004875ma
85volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00053125ma
92volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.000575ma
99volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00061875ma
106volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0006625ma
113volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00070625ma
120volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00075ma
127volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00079375ma
134volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0008375ma
141volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00088125ma
148volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.000925ma
155volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00096875ma
162volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0010125ma
169volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00105625ma
176volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0011ma
183volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00114375ma
190volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0011875ma
197volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00123125ma
204volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.001275ma
211volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00131875ma
218volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0013625ma
225volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00140625ma
232volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00145ma
239volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00149375ma
246volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0015375ma
253volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00158125ma
260volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.001625ma
267volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00166875ma
274volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0017125ma
281volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00175625ma
288volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0018ma
295volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00184375ma
302volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0018875ma
309volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00193125ma
316volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.001975ma
323volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00201875ma
330volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0020625ma
337volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00210625ma
344volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00215ma
351volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00219375ma
358volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0022375ma
365volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00228125ma
372volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.002325ma
379volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00236875ma
386volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0024125ma
393volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00245625ma
400volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0025ma
407volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00254375ma
414volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0025875ma
421volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00263125ma
428volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.002675ma
435volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00271875ma
442volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0027625ma
449volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00280625ma
456volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00285ma
463volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00289375ma
470volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.0029375ma
477volts, Skin Resistance: 160kohms, Potential Current Flowing: 0.00298125ma
Something's not adding up? and that's with a tight grip.....
t06afre
Joined May 11, 2009
5,934
Ironically, you can use a multi meter to measure the resistance of your skin quite safely, but if you poked in a bit deeper into your flesh, it could kill you... I think the human normal dry skin is around 500k, a fair bit lower if wet/clammy ... and yeah a 9volt battery is enough to stop your heart.
NO NOT very likely. I guess the current from a multimeter or a 9 volt battery could kill if you drove the measurement probes directly into the heart. But what situation would cause that to happened:eek:. If things escalate to such a level. You will most probably die any way
cjdelphi
Joined Mar 26, 2009
272
No wonder... it's 10uA not 10ma, now my maths makes sense...
[/quote]
If an electrical circuit is established by electrodes introduced in the body, bypassing the skin, then the potential for lethality is much higher if a circuit through the heart is established. This is known as a microshock. Currents of only 10 µA can be sufficient to cause fibrillation in this case.[citation needed] This is a concern in modern hospital settings when the patient is connected to multiple devices.
cjdelphi
Joined Mar 26, 2009
272
I think you'll find it's already happened to someone in the navy i think he was, he dug the probes in to see his internal resistance and well, died....
t06afre
Joined May 11, 2009
5,934
To me this sounds like pure gobbledygook. Do you have any credible references to this story.
By the way. In order to get proper measuremnts on the skin electrical properties you need to use biopotential electrodes. The current flow in the human body is due to ion flow, not electrons. A biopotential electrode is a transducer that senses ion distribution on the surface of tissue, and converts the ion current to electron current. The skin conductance is only linear if the current density is less than 10uA pr cm^2 of skin
TBayBoy
Joined May 25, 2011
148
Just to throw in somethings here, the body is measured in impedance not just resistance, also energy flow past the skin surface requires special licensing (in North America at least) so don't just willie nillie start to experiment. :)
Finally, newer defibrillators on the market, measure body impedance first with a "probe signal" then adjust the level of shock to deliver all without puncturing the skin, so barrier is more a biological term rather than electrical one. :)
someonesdad
Joined Jul 7, 2009
1,583
Folks who fool around with electricity should have some order-of-magnitude estimates of what currents are dangerous. It's not terribly important whether the current is DC or AC, although the body's sensitivity to higher frequency currents falls off a bit with increasing frequency (but don't interpret that to mean that the higher frequency currents are harmless, as anyone who has gotten an RF burn will attest to).
I emphasize -- these are order-of-magnitude numbers. Do proper research if you want "exact" numbers, although the clinical variations between humans and shock situations will add fuzziness, not to mention that it's difficult to get exact figures in the laboratory without injuring or killing the subject, something most folks would probably object to, particularly the subject.
Humans start to sense electrical currents around 1 mA. This is why leakage current specifications usually set an upper limit of about 500 μA or less. A current on the order of 1 mA can be hazardous -- but not directly. The reason is that a shock can startle a person and cause a reflex action -- which might cause some harm. Think of being next to a sharp sheet metal edge and jerking back when you get a shock, giving yourself a nasty cut.
Around 10 mA is where it can become difficult to let go of a conductor when you're getting a shock. Half of this value is where most ground fault interrupter circuits are designed to open (the ones I've measured all trip between about 4.5 and 5 mA).
100 mA is where ventricular fibrillation occurs (I've seen the range quoted from 100 to 200 mA). This is an abnormal pumping action of the heart (it quivers and doesn't pump) and leads to death in short order because little blood is being pumped.
Currents 1 A and above are where burns happen. They can be especially nasty when associated with an arc flash -- a plasma caused by high currents that can be in the tens to hundreds of thousands of amps (or more). This is why, for example, you want to use Cat IV rated DMMs when working on primary electrical feeds.
I've seen the statements about the sailor testing himself with an ohmmeter and dying from a shock, but I've never seen a properly-attributed reference to it. Thus, I consider it an urban legend/hearsay until otherwise debunked. Modern digital multimeters measure resistance by supplying a constant current through the unknown resistance. For example, my 20 year old Fluke 83's manual specifies the maximum typical short-circuit current when measuring resistance to be 0.7 mA (my meter's actual value is 286 μA). It would be hard to see that current level causing a problem with the probes touching skin, but I suppose if you jammed the probes to where they were within a mm or two of the heart or in the brain, you might have some shock issues. Again, the subject will probably object though.
You can measure the short circuit current of your multimeter's resistance ranges by connecting the leads to another multimeter that's set to read current. The lowest resistance range will have the highest current.
Don't forget that the shock might not be the thing that kills you. I got hit once by under 50 volts while on a step stool. When the world refocused around me I has flat on my back about 6 feet from the stool with a large bump on the side of my head from the fall. The damage on my finger was just a little redness but the fall could have broken my neck.
steev
Joined Jun 12, 2011
7
Hi All,
Thanks for all your answers and input - very interesting.
To have as much knowledge of electricity as possible is good!!!
Thanks again
Steve
someonesdad
Joined Jul 7, 2009
1,583
Decades ago I was in a physics lab alone late one night poking around in some circuitry I shouldn't have been poking around in. I hit something with my finger, then it knocked me for a loop. The next thing I remember is hearing a big bang and I was laying on my back looking up at the lights. The bang I heard was the big lab table hitting the ground after my legs jerked up in a spasm, lifting the whole thing off the ground.
I had two truly epic bruises on the tops of my thighs. Of course, that was a lesson I never, never forgot and turned me into a bit of a safety Nazi...
strantor
Joined Oct 3, 2010
6,875
I can't attest to this specific story per se, but I have witnessed Navy Nuclear Electricians Mates (supposedly the smartest people in the navy) taking turns shocking eachother with a megger. There was a memo issued on this specific issue, so I assume there was an incident. I wouldn't be too surprised to hear that one died at the probes of a megger, and a megger could easily turn into a DMM through a few retellings of the story.
JoeJester
Joined Apr 26, 2005
4,390
If there was a death due to multimeter, there would be a mishap report and the subsequent all hands training about doing stupid things.
Have you heard of people testing 9V batteries with their tongue? I would say the resistance of the tongue is much lower than between the fingers.
Remember, know what your doing because the a$$ you save may be your own. Otherwise, do the world a favor and write your own submission for a Darwin Award.
Wendy
Joined Mar 24, 2008
23,797
Tongue testing goes toward current path. If you induce a current between both hands it will go through the heart. This is why you will hear people talking about one hand in the pocket. I don't do it myself, I just pay close attention where my hands are, but I understand the logic.
I think most folks can come up with really stupid stuff they have done. I know I can, like the time I was groping blind for the water cut off inside an old laser after it sprung a major leak, knowing there was a couple of farads within a foot charged to 300VDC. It may not have killed me, but I suspect I would have been nicknamed Lefty if I had screwed up.
NickNYC
Joined Jun 30, 2011
12
A static electricity shock flowing from your feet, through you into a doorknob, and then into ground, is thousands of volts, but at microamps.
If 10 amps flowed through you at the same voltage as a static shock, you'd be bacon. Jack Nicholson would be leering at you yelling "I'm glad you're dead!" So it's generally true that it's the amperage that's dangerous.
Another way to look at it is if someone throws a BB at your head, and then someone throws a brick at your head with the same force. Not hard to figure out what's going to cause more damage.
34,886
I come from the "one hand in the pocket" school. I will generally do this whenever I am poking around anything over 50V.
monster_catfish
Joined Mar 17, 2011
116
I have a follow up question about the risk of electric shock while soldering. Is there any potential at all for faulty soldering iron held in one hand, and bare solder wire held in the other, to send current through the heart ?
I was so troubled by that thought that I held the solder wire with a thick glove when I recently started doing solder work for the first time in a good while.
