Hi I want to ask everybody who know this : was the leg notation for base, collector and emitter for BC547 transistor are similar even though they are manufactured by different manufacturer? Thank you
Google is your friend for finding data sheets. Just Google BC547. And you will get tons of links to data sheet.http://malaysia.rs-online.com/web/p...3743D4243203534372673633D592677633D4E4F4E4526
This was the transistor I meant but can't find its manufacturer datasheet
Yeah, i tried google it but never found datasheet for this transistor's company except others. And I worried that leg notation for C,B and E would not be same if using other company's datasheetGoogle is your friend for finding data sheets. Just Google BC547. And you will get tons of links to data sheet.
I see... Do all manufacturers follows a standard on every leg's component especially transistor to ease the user?It should be the same, as they are meant to be compatible.
