The attached pic is the the small pcb of a (typical?) cheapo quartz clock. The output is 1 pps but the polarity is reversing. I believe it's basically a current drive but the open circuit amplitude of the pulses may be about 150mV. I can't fathom out the relationship between the o/p voltage and and the 1.5v supply.
I's like to use it to drive an industrial style clock that requires alternating polarity pulses of 24v. at about 250mA. If they were simple uni-directional pulses it would be easy to amplify them to 24v... but I can't even start to think how to do it. Any thoughts ?
