Quadrature encoding screened lead
camerart
Joined Feb 25, 2013
3,846
I'm using quadrature encoding on a project I'm working on. I think it is better to use screened lead for the signals, and have been testing using good quality stereo cable, which is quite stiff. I would prefer more flexible lead if possible as it needs to coil a little. Does anyone have any suggestions for what would be the most flexible type of lead for my purpose, please? It also needs a small 5v power wire, plus gnd. (Can the screened earth be also used for power?) All less than 1Mtr.
Camerart.
30,758
No you should not use the Shield/Screen for power.
Particularly if using single ended output and not using differential output, is it a noisy environment?
camerart
Joined Feb 25, 2013
3,846
Ok, John
Hi M.
What is single ended and differential output?
I have the ground connected only at the circuit end.
Noisy? The motors are switching and commutating, and there are transmitter/receivers all withing 1/2 Mtr.
Is Joh's suggestion of headphone wire ok?
C.
30,758
Encoders often do not act alone but in an otherwise electrically noisy environment as in CNC machine etc, so it is important to prevent noise appearing in the signal in this case a differential output such as RS485 driver is used, for short distances you can get away with single ended. But should still important for shielding. See maxim MAX9112
Could be overkill maybe in your case, but I use individual shielded pairs with OA braid shield.
camerart
Joined Feb 25, 2013
3,846
Pardon my ignorance guys. Googled the term with no luck.
What is a screened lead?
Hi B,
The insulated +v wires in screened lead are covered by braiding, which is the Gnd side, instead of two parallel wires. Used in earphone, microphone, USB, signal cables to stop interference getting into the signal.
C.
BR-549
Joined Sep 22, 2013
4,928
Still have no idea. You said it was stiff. Could you possibly mean coax cable?
What term do you use, when you search for this product on google?
All I get is screening for lead poisoning.
30,758
The encoder cable I use is actually intended for Data transmission and it has each pair shielded by foil shield and has an overall braid shield.
It also has one pair one gauge up from the rest for the power.
But this is used in a noisy industrial environment.
NOT cheap though.:(
camerart
Joined Feb 25, 2013
3,846
I looked in my old cable box and found some quality Phono cable with four individually screened cables, and it is remarkably flexible too. I'll use that.
Thanks to everyone.
C,
